dt = Open( "$SAMPLE_DATA/Liver Cancer.jmp" );
obj1 = dt << Run Script( "Lasso Poisson, Validation Column" );
Print( "Running " || case_name );
Print( "Generate Python Code" );
Save Text File( dest_dir || case_name || ".py", code );
Print( "Code generation failed for " || case_name || ", reason: " );
fdw = Window( "Report: Formula Depot" );
fdw << Close Window( No Save );
