JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Three-Dimensional Scenes
Lighting and Normals
• Lighting Models
上一个
下一个
Lighting Models
Lighting models are specified with the
Light Model
command.
Light Model( argument, value,...,value )
Light models specify three attributes of lights.
The global ambient light intensity
Whether the viewpoint is local or is an infinite distance away
Whether lighting calculations should be performed differently for the front and back faces of objects.
Light Arguments and Default Values
shows the three valid arguments for the
Light Model
command.
Light Model Arguments and Default Values
Argument
Default Value
Meaning
LIGHT_MODEL_AMBIENT
(0.2, 0.2, 0.2, 1)
Ambient RGBA intensity of the entire scene
LIGHT_MODEL_LOCAL_VIEWER
0 (false)
how specular reflection angles are computed
LIGHT_MODEL_TWO_SIDE
0 (false)
nonzero values imply two-sided lighting
