JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Three-Dimensional Scenes
Lighting and Normals
• Normal Vectors
上一个
下一个
Normal Vectors
Normal vectors point in a direction perpendicular to a surface. For a plane, all normals are the same. For a more complicated surface, normals are more complicated. JSL enables you to specify the normal vector for each vertex. These normals specify the orientation of the surface in space, necessary for lighting calculations. Accurate normals assure accurate lighting.
The normal vector is of length 1 and is perpendicular to the vertex. Typically, a vertex is shared between several polygons and a smooth shaded effect is desired, so the perpendicular at the vertex is calculated as a (possibly weighted) average of the polygon’s normals. It is important to calculate the “outward” normal for polygons unless two-sided shading is enabled because only the outer face of the polygon is illuminated. With a scaled polygon, the normal’s length is not 1 after scaling, and the lighting is wrong.
Normal vectors are set at the same time the surface is constructed, and are specified with the
Normal
command. Use the
Enable(NORMALIZE)
command to have the normals re-normalized to 1 each time the scene is drawn.
