dt = Open( "$SAMPLE_DATA/Wafer Stacked.jmp" );
Min Distance( 12 ), // minimum distance among 3 points to seed an arc
Min Radius( 15 ), // minimum radius of the acceptable arc
Max Radius( 2000 ), // maximum radius of acceptable arc
Max Radius Error( 2 ), // how close a point needs to be added
Min Arc Points( 5 ), // how many points to define an arc
Number of Searches( 500 ), // how many random probes of data
Max Number Arcs( 3 ) // number of arcs searched for
dt << Color or Mark by Column( :Arc Number );
dt << Graph Builder(
Size( 1539, 921 ),
A vector of forecasted values for column within the range defined by from and to.
A list of named values that matches the messages sent to ARIMA Forecast(). If you perform an ARIMA Forecast and save the script, the estimates are part of the script.
Define the range of values. Typically, from is between 1 and to, inclusive. If from is less than or equal to 0, and if from is less than or equal to to, the results include filtered predictions.
Returns the cumulative sum for the current row. Col Cumulative Sum supports By columns, which do not need to be sorted.
If a data value is assigned by a column property (such as Missing Value Codes), use Col Stored Value() to base the calculation on the value stored in the column instead. See Col Stored Value(<dt>, col, <row>).
Col Moving Average( x, 1, 4 );
Col Moving Average( x, 0, 2, 2 );
Col Moving Average( x, 0.25 );
Calculates the specified quantile p across all rows of the specified column. The result is internally cached to speed up multiple evaluations.
a specified quantile p between 0 and 1.
Col Quantile( :height, .5 );
Determines how the tie is broken. A tie occurs when the values being ranked are the same. For the data [33 55 77 55], 33 has rank 1 and 77 has rank 4, and the question is how to assign ranking for the 55s. average reports the average of the possible rankings, 2.5, for both 55s. arbitrary matches JMP 12 behavior by assigning the possible rankings in an unspecified order, which could be 2 and 3 or 3 and 2. row assigns the ranks in the order that they originally appear. (The first 55 would be 2 and the second 55 would be 3.)
minimum gives both values the lowest possible rank, 2.
dt << New Column( "stdht", Formula( Col Standardize( height ) ) );
dt << New Column( "stdht2",
Formula( (height - Col Mean( height )) / Col Std Dev( height ) )
Calculates the sum across rows in a column. Calculating all missing values (Col Sum(.,.)) returns missing. The result is internally cached to speed up multiple evaluations.
Fit Censored(Distribution("name"), YLow(vector) | Y(Vector), <YHigh(vector)>, <Weight(vector)>, <X(matrix)>, <Z(matrix)>, <HoldParm(vector)>, <Use random sample to compute initial values(percent)>, <Use first N observations to compute initial values(nobs)>)
If you do not have censoring, then use Y and an array of your data, and do not specify YHigh. If you do have censoring, then specify YLow and YHigh as the lower and upper censoring values, respectively.
n must be 0, 1, 2, or 3, corresponding to Sheather and Jones, Normal Reference, Silverman rule of thumb, or Oversmoother, respectively.
n must be 0, 1, 2, 3, or 4, corresponding to Gaussian, Epanechnikov, Biweight, Triangular, or Rectangular, respectively.
Multiplies the results of bodyExpr over all i until the limitValue and returns a single product.
Returns the pth quantile of the arguments. The first argument can be a scalar or a matrix of values between 0 and 1. The remaining arguments can also be specified as values within a single matrix or list argument.
A data table of p-values and LogWorth values for each Y and X combination. See ““PValues”数据表” in Predictive and Specialized Modeling.
Performs the same function as the Response Screening platform. See “响应筛选” in the Predictive and Specialized Modeling book for details.
Summation sums the results of the body statement(s) over all i to return a single value.
Constructs a 1-alpha confidence interval to contain proportion p of the means with sample size n.
