数值格式 in the Using JMP book describes the arguments. Note that Matrix Box(), Number Col Box(), Number Col Edit Box(), Number Edit Box() have the same Set Format syntax.
For a list of currency codes, see “Currency” in the Scripting Guide. The currency code is based on the locale if the code is omitted.
