Activates Box Plots from the Display Options menu. See Quantiles.
Note: If the X factor has two levels, the menu option changes to Means/Anova/Pooled t and produces a Pooled t-test report assuming equal variances.
(Available only if the X factor has two levels.) Produces a t-test report assuming that the variances are not equal. See The t-test Report.
Set α Level
You can select an option from the most common alpha levels or specify any level with the Other selection. Changing the alpha level results in the following actions:
Plot Actual by Quantile generates a quantile plot with the response variable on the y-axis and quantiles on the x-axis. The plot shows quantiles computed within each level of the categorical X factor.
Plot Quantile by Actual reverses the x- and y-axes.
Line of Fit draws straight diagonal reference lines on the plot for each level of the X variable. This option is available only once you have created a plot (Actual by Quantile or Quantile by Actual).
Save Residuals saves values computed as the response variable minus the mean of the response variable within each level of the factor variable.
Save Standardized saves standardized values of the response variable computed within each level of the factor variable. This is the centered response divided by the standard deviation within each level.
Save Normal Quantiles saves normal quantile values computed within each level of the categorical factor variable.
Save Predicted saves the predicted mean of the response variable for each level of the factor variable.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 10/11/2018
