(Available only when one or more supercategories is defined.) Shows or hides columns for supercategories in the Crosstab table and the Frequency Chart. For more information about supercategories, see Supercategories.
Tip: This option shows or hides the Supercategories. To hide the individual categories within the supercategory, use the Hide option in the Supercategories column property. Alternately, use the Response Levels option to hide all response levels so that only Supercategories remain unhidden.
Shows or hides the Compare Means column in the Crosstab table. This column compares the mean scores across grouping categories using the unpooled Satterthwaite t test for pairwise comparisons. See SAS Institute Inc. (2017). The results of the comparison are shown using letters. For more information about comparison letters, see Comparison Letters. For more information about specifying comparison groups, see Example of User-Specified Comparison with Comparison Letters.
Shows or hides the local data filter that enables you to filter the data used in a specific report. Sample levels that contain no responses are always hidden. To show the filtered headings in reports, select Include Responses Not in Data in the launch window. You can also select the Set Preferences red triangle menu and then select Include Responses Not in Data.
Enables you to set preferences for future launches of the Categorical platform in the current JMP session as well as in future JMP sessions. For more information, refer to Set Preferences.
Contains options (Grouping Option, Count Missing Responses, Order Response Levels High to Low, Shorten Labels, and Include Responses Not in Data) that are also presented on the launch window. If these options are selected here, the platform updates with the new setting. For more information about the Category Options, see Other Launch Window Options.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
