Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Hierarchical Cluster
Launch the Hierarchical Cluster Platform
• Clustering Method
Clustering Method
Hierarchical is the default clustering method, but the dialog enables you to switch to KMeans or Normal Mixtures. If you select KMeans or Normal Mixtures, when you click OK, a Control Panel appears where you can select any of the following as Method:
K-Means Clustering
See the
K Means Cluster topic
Normal Mixtures
See the
Normal Mixtures topic
Robust Normal Mixtures
See
Normal Mixtures NCluster=<k> Report
in Normal Mixtures
Self Organizing Map
See
Self Organizing Map
in K Means Cluster
Help created on 7/12/2018
