Applicable when both Y or X are ordinal or interval. The alternative hypothesis is that there is a linear association between Y and X in at least one level of the blocking variable.
Applicable when Y is ordinal or interval. The alternative hypothesis is that, for at least one level of the blocking variable, the mean scores of the r rows are unequal.
Applicable when X is ordinal or interval. The alternative hypothesis is that, for at least one level of the blocking variable, the mean scores of the c columns are unequal.
