Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Contingency Analysis
Correspondence Analysis
• The Details Report
The Details Report
The Details report contains statistical information about the correspondence analysis and shows the values used in the plot.
Singular Value
Provides the singular value decomposition of the contingency table. For the formula, see
Details Report in Correspondence Analysis
Inertia
Lists the square of the singular values, reflecting the relative variation accounted for in the canonical dimensions.
Portion
Portion of inertia with respect to the total inertia.
Cumulative
Shows the cumulative portion of inertia. If the first two singular values capture the bulk of the inertia, then the 2-D correspondence analysis plot is sufficient to show the relationships in the table.
X variable c1, c2, c3
The values plotted on the Correspondence Analysis plot (
Figure 6.105
Y variable c1, c2, c3
Figure 6.105
Help created on 7/12/2018
