Add your own menu items to the main menu bar in JMP. These menus appear before or after menus such as File, Edit, and Tables. An untitled command is inserted automatically in the menu, because all menus must have at least one command.
When you want to create a main menu based on an existing menu, make a copy of the existing menu and then change settings as necessary. See Copy and Paste Menus, Menu Items, Toolbars, and Buttons for details.
Select View > Customize > Menus and Toolbars.
Complete Step 2: Specify the Caption and Internal Name to rename the main menu.
7.
Click Save to save your changes.
