When you want to create a toolbar based on an existing toolbar, make a copy of the existing toolbar and then change settings as necessary. See Copy and Paste Menus, Menu Items, Toolbars, and Buttons for details.
Select View > Customize > Menus and Toolbars.
Select New Toolbar.
The caption appears in the View > Toolbars list, which lets you show or hide the toolbar. Give each toolbar a unique name. JMP merges toolbars with the same name after you close and reopen the Menu Editor.
Enter the internal name next to Internal name.
Enter a unique name for the toolbar or button in the Caption box.
Click the Localize button for the item that you want to customize.
Click OK.
(Optional) Click Hidden to keep the toolbar hidden after creation.
7.
Click Save to save your changes.
