Consider the data used in Example of a V-Mask CUSUM Chart, where the machine fills 8-ounce cans of engine oil. In order to cut costs, the manufacturer is now concerned about significant over-filling (and not so concerned about under-filling). Use a one-sided CUSUM chart to identify any instances of over-filling. Anything that is 0.25 ounces beyond the mean of 8.1 is considered a problem.
Select Analyze > Quality And Process > Control Chart > CUSUM.
Deselect Two Sided.
Click H and type 0.25.
7.
Click Specify Stats.
8.
Type 8.1 next to Target.
9.
Type 1 next to Delta.
10.
Type 0.05 next to Sigma.
11.
Click OK.
