Shows prediction traces for each X variable. Enables you to find optimum settings for one or more responses and to explore response distributions using simulation. See Profiler and Profiler in the Profilers book.
Shows a matrix of interaction plots, when there are interaction effects in the model. See Interaction Plots.
Provides an interactive contour profiler, which is useful for optimizing response surfaces graphically. See Contour Profiler and Contour Profiler in the Profilers book.
Shows response contours of mixture experiment models on a ternary plot. See Mixture Profiler and Mixture Profiler in the Profilers book.
Shows predicted values for the extremes of the factor ranges laid out on the vertices of cubes. See Cube Plots.
Finds a Box-Cox power transformation of the response that is best in terms of satisfying the normality and homogeneity of variance assumptions. See Box Cox Y Transformation.
Shows a three-dimensional surface plot of the response surface. See Surface Profiler and Surface Plot in the Profilers book.
