Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Fitting Options
• Fit the Same Option Multiple Times
You can select the same fitting option multiple times, and each new fit is overlaid on the scatterplot. You can try fits, exclude points and refit, and you can compare them on the same scatterplot.
To apply a fitting option to multiple analyses in your report window, hold down the Ctrl key and select a fitting
option.
Help created on 7/12/2018
