Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Fitting Options
• Fitting Option Categories
Fitting option categories include regression fits and density estimation.
Category
Description
Fitting Options
Regression Fits
Regression methods fit a curve to the observed data points. The fitting methods include least squares fits as well as spline fits, kernel smoothing, orthogonal fits, and robust fits.
Fit Mean
Fit Line
Fit Polynomial
Fit Special
Flexible
Fit Orthogonal
Robust
Density Estimation
Density estimation fits a bivariate distribution to the points. You can either select a bivariate normal density, characterized by elliptical contours, or a general nonparametric density.
Density Ellipse
Nonpar Density
Help created on 7/12/2018
