A plot of the average measurement values for each combination of the part and X variables. The Average Chart helps you detect product variation despite measurement variation. In an Average Chart, out of control data is desirable because it detects part-to-part variation. See Average Chart.
A plot of the variability statistic for each combination of the part and X variables. Appears only if you selected Range as the Chart Dispersion Type in the launch window. The Range Chart helps you check for consistency within subgroups. In a Range Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
A plot of the standard deviation statistic for each combination of the part and X variables. Appears only if you selected Standard Deviation as the Chart Dispersion Type in the launch window. The Standard Deviation Chart helps you check for consistency within subgroups. In a Standard Deviation Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
a report that computes several statistics to help you assess and classify your measurement system. See EMP Results.
an Analysis of Means chart for testing if the X variables have different averages. See Bias Comparison.
an Analysis of Means for Variances or Analysis of Means Ranges chart for testing if any of the groups have different test-retest error levels. See Test-Retest Error Comparison.
an interactive set of charts that you can adjust to see the probabilities of getting warnings on your process behavior chart. See Shift Detection Profiler.
Note: This report is similar to the Variance Components report in the Variability Chart platform, except that it does not compute Bayesian variance component estimates. For more information, see Variance Components in Variability Gauge Charts.
Note: This report is similar to the Gauge R&R report in the Variability Chart platform, except that the calculation for Reproducibility does not include interactions. For more information about Gauge R&R studies, see About the Gauge R&R Method in Variability Gauge Charts.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
