Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability Block Diagram
The Reliability Block Diagram Window
• Preview Window
Preview Window
When the system diagram is too large to appear in the workspace, the Preview window enables you to reposition the portion of the system diagram that appears in the workspace. Drag the viewing area, which is indicated in the Preview window by a white background, to reposition the view of the Workspace to another part of the system diagram.
Figure 10.13
Preview Window with Visible Part of Diagram on White Background
Help created on 7/12/2018
