Enables you to save a Reliability Block Diagram, or save an existing Reliability Block Diagram with a new name, to a JMP Scripting Language (JSL) script that is automatically executed when it is opened in JMP. See Advanced Note: Auto-Submit in the Scripting Guide for details on Auto-Submit scripts.
If Show Design Comparisons is selected, this option enables you to hide or show the system diagram in the Workspace.
Displays a Distribution Overlay profiler and Remaining Life Distribution Overlay profiler for the selected system diagrams. See Show Design Comparisons for details.
Enables you to add a new design diagram to the Designs panel. See Add a New Design Item for details.
Enables you to add a new item to the Library panel. The Library panel lets you create subsystem diagrams for use in multiple system designs. See Add a New Library Item for details.
The Show Design Comparisons option displays a Distribution Overlay plot and a Remaining Life Distribution Overlay plot. These plots appear in the Workspace below the System Diagram. See Figure 10.14 and Figure 10.15.
Tip: To hide the system diagram in the Workspace, from the Reliability Block Diagram red triangle menu, deselect Show Design Diagram. Alternatively, to show more of the Design Comparisons, reposition the horizontal splitter upward.
Figure 10.14 Distribution Overlay Example
Figure 10.15 Remaining Life Distribution Overlay Example
The New Design Item option adds a new system design to the Designs panel list.
From the Reliability Block Diagram red triangle menu, select New Design Item.
The New Library Item option adds a new sub-system to the Library panel list.
From the Reliability Block Diagram red triangle menu, select New Library Item.
