Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
• Reliability Block Diagram
Engineer System Reliabilities
The Reliability Block Diagram platform is available only in JMP Pro.
The Reliability Block Diagram platform displays the reliability relationships among a system's components. If reliability distributions are assigned to the components, the platform analytically models the reliability behavior. A Reliability Block Diagram (also known as a dependence diagram) illustrates how component reliability contributes to the success or failure of a system.
Figure 10.1
Example of a Reliability Block Diagram
Contents
Overview of the Reliability Block Diagram Platform
Example Using the Reliability Block Diagram Platform
Add Components
Align Shapes
Connect Shapes
Configure Components
The Reliability Block Diagram Window
Preview Window
Reliability Block Diagram Platform Options
Workspace Options
Configuration Settings
Distribution Configurations
Specify a Nonparametric Distribution
Options for Design and Library Items
Profilers
Component Importance and Time to Failure
Component Plots
Print Algebraic Reliability Formula
Clone and Delete
Help created on 7/12/2018
