Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
V-Mask CUSUM Control Charts
• The V-Mask CUSUM Control Chart
CUSUM charts can be one-sided or two-sided. One-sided charts detect a shift in one direction from a specified target mean. Two-sided charts detect a shift in either direction.
Follow the instructions in
Example of a V-Mask CUSUM Chart
to produce the results shown in
Figure 5.5
Figure 5.5
Example of a Two-Sided CUSUM Chart
Note the following:
If you use the grabber tool and click on a point, the shift and V-mask adjust to reflect the process condition at that point.
If you add new data to the data table for an existing CUSUM chart, the corresponding chart updates automatically.
For information about additional options, see
V-Mask CUSUM Control Chart Platform Options
Help created on 7/12/2018
