Essential Graphing > Bubble Plots
Publication date: 06/21/2023
Bubble Plots
View Patterns in Multidimensional Data Using Bubble Plots
A bubble plot is a scatterplot that represents its points as circles, or bubbles. Bubble plots can be dynamic (animated over time) or static (fixed bubbles that do not move). Use bubble plots to:
dynamically animate bubbles using a time variable, to see patterns and movement across time
use size and color to clearly distinguish between different variables
aggregate data (rows) into a single bubble, simplifying the bubble plot
Because you can see up to five dimensions at once (x position, y position, size, color, and time), bubble plots can produce dramatic visualizations and readily show patterns and trends.
Note: Dynamic bubble plots were pioneered by Hans Rosling, Professor of International Health, Karolinska Institutet, and the people involved in the Gapminder.org project.
Figure 5.1 Example of a Bubble Plot
Contents
Example of a Dynamic Bubble Plot
Launch the Bubble Plot Platform
Specifying Two ID Variables
Specifying a Time Variable
Interact with the Bubble Plot
Control Animation for Dynamic Bubble Plots
Select Bubbles
Use the Brush Tool
Bubble Plot Platform Options
Change Variables in a Bubble Plot
Additional Examples of the Bubble Plot Platform
Example of a Time Variable and no ID Variable
Example of ID Variables and no Time Variable
Example of a Static Bubble Plot
Example of a Bubble Plot with a Categorical Y Variable
