Use the Degradation platform to analyze degradation data and produce pseudo failure times. These pseudo failure times can then be analyzed by other reliability platforms to estimate failure distributions.
Both linear and nonlinear degradation paths can be modeled. You can specify an accelerating factor to analyze accelerated degradation data.
You can also perform stability analysis, which is useful when setting pharmaceutical product expiration dates.
Figure 16.1 Degradation Analysis Example
