Profilers > Profiler
Publication date: 07/08/2024
Profiler
Explore Cross Sections of Responses across Each Factor
The Prediction Profiler gives you a wealth of information about your model. Use the Prediction Profiler to do the following:
See how your prediction model changes as you change settings of individual factors.
Set desirability goals for your response or responses, and find optimal settings for your factors.
Gauge your model’s sensitivity to changes in the factors, where sensitivity is based on your predictive model.
Assess the importance of your factors relative to model predictions, in a way that is independent of the model.
Simulate your response distribution based on specified distributions for both factors and responses, and control various aspects of the appearance of the profiler.
Figure 3.1 Prediction Profiler for Four Responses with Simulator and Importance Coloring
Contents
Overview of the Prediction Profiler
Example of the Prediction Profiler
Launch the Prediction Profiler Platform
Prediction Profiler Options
Maximization Options Window
Desirability Profiling and Optimization
Construction of Desirability Functions
How to Use the Desirability Function
The Desirability Profile
Customized Desirability Functions
Assess Variable Importance
Bagging
Design Space Profiler
Design Space Profiler Report
Design Space Profiler Options
Additional Examples of the Prediction Profiler
Example of a Desirability Profiler for Multiple Responses
Example of a Noise Factor in the Prediction Profiler
Example of Variable Importance for One Response
Example of Variable Importance for Multiple Responses
Example of Bagging to Improve Prediction
Example of Bagging to Indicate the Accuracy of Predictions
Example of Confidence Intervals Using Bagging
Example of Confidence and Prediction Intervals Using Formulas
Example of Design Space Profiler
Statistical Details for the Prediction Profiler
Statistical Details for Assess Variable Importance
Statistical Details for Propagation of Error Bars
Statistical Details for Extrapolation Control Metrics
