DRAFT help
Publication date: 09/20/2024
Response Options
In the Fit Least Squares report, the red triangle menu options for the response give you the ability to customize reports according to your needs.
Regression Reports
Provides basic reports and report options. See Regression Reports.
Estimates
Provides options for further analyses relating to parameter estimates. See Estimates.
Effect Screening
Provides reports and plots for identifying significant effects. See Effect Screening.
Factor Profiling
Provides profilers, interaction, and cube plots to examine how the response is related to the model terms. Also provides a plot and report for fitting a Box-Cox transformation. See Factor Profiling.
Row Diagnostics
Provides plots and reports for examining residuals. Also reports the PRESS statistic and provides a Durbin-Watson test. See Row Diagnostics.
Save Columns
Saves model results as columns in the data table, except for Save Coding Table, which saves results in a separate data table. See Save Columns.
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
Effect Summary
Shows or hides the Effect Summary report, which enables you to interactively update the effects from the model. See Effect Summary Report.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
