Using JMP > JMP Preferences
Publication date: 02/06/2025
JMP Preferences
The Preferences Window
JMP preferences enable you to specify general and specific settings and save the settings.
To change preferences
1. Select File > Preferences (Windows) or JMP > Preferences (macOS). The window in Figure 15.1 appears. The previous preferences page that you selected appears.
2. Click a category and make selections. Click Apply to see the results, and then click OK.
Notes:
When you upgrade a subscription product, changes to preferences are maintained. In other JMP versions, you must customize the preferences after each upgrade.
Your JMP preferences are remembered if you switch the JMP display language.
To search preferences
2. In the Filter box at the top, enter your text.
3. (Optional) To filter preferences by the version of JMP they were added in, click Version and choose minimum and maximum versions.
4. At left, click a category to see its results.
Matches are highlighted in blue. If you filter by version, the version number appears in a circle.
A search term can show up in these places:
the preference itself
a tooltip for the preference
a list of options for a preference
To reset preferences to the default settings
2. Click Reset All, and then click OK.
Contents
Overview of JMP Preferences
General JMP Preferences
Preferences for JMP Reports
Preferences for JMP Graphs
Style Preferences for JMP Graphs and Reports
Fonts Preferences
Menu Preferences
Preferences for JMP Projects
Preferences for Data Tables
Preferences for JMP Data Filters
Preferences for the Column Switcher
Preferences for the Columns Manager
Preferences for Recoding Columns
Value Order Preferences
Preferences by JMP Platform
Preferences for Platform Presets
Preferences for Importing and Exporting Text Files
Preferences for Third-Party Data
Preferences for the Query Builder
Preferences for the JSL Script Editor
Preferences for the Workflow Builder
Preferences for the JSL Debugger
Preferences for the Log
Windows Preferences
Mac OS Preferences
Communications Preferences
Preferences for Internet Options
Print Preferences
Preferences for File Locations
Preferences for Updating JMP
Privacy Preferences
