Using JMP > Import Your Data
Publication date: 02/06/2025
Import Your Data
Create Data Tables
This chapter covers the following topics:
How to import data, such as text files, PDF files, SPSS files, and SAS data
How to transfer Excel data
How to read in real-time data
How to create a new data table
Figure 3.1 Importing a Text File
Contents
About Importing Data
Import Microsoft Excel Files
Preview and Import Microsoft Excel Data
Import a Microsoft Excel File Directly
Import Text Files
Find Missing Characters in Imported Data
Options in the JMP Text Import Wizard
Edit Text Before Importing into JMP
Import Text from the Script Editor
Import Multiple Files
Import CSV Data with Different Quoting
Import Settings
Import PDF Files
Concatenate Tables into One Data Table
Concatenate Tables by Column Headers
Import Tables that JMP Does Not Auto-Detect
PDF Preview Red Triangle Options
Data Table Preview Options
PDF Preview Right-Click Options
Import XML and JSON Files
Preview and Import XML and JSON Data
Import XML Files Directly
Import JSON Files Directly
Build SQL Queries in Query Builder
Connect to a SQL Database
Select Tables from a SQL Database
Build a SQL Query
Save and Run a JMP Query
Open the Selected Data
Query Builder Red Triangle Options
Write SQL Statements in Query Builder
Import Data from SAS
Import SAS Data Sets
Create SAS Transport Files in SAS from JMP
Using SAS Extended Attributes to Import Metadata
Import Data from a Database
Connect to a Database using Data Connectors
Connect to a Database With Open Table
Structured Query Language (SQL): A Reference
Import Data from Google Sheets
About Importing Google Sheets
Google Sheet Settings
Import SPSS Files
Import Triple-S Survey Data
Import HDF5 Data
Import Data from MATLAB
Import Data from R
Import Data Using the Excel Add-In
Transfer Excel Data to a Data Table
About the JMP Add-In for Excel
Uninstall the JMP Excel Add-In
Import Data from the Internet or a Remote Computer
Create New Data Tables
Import Data from a PI Server
Connect to a PI Server
Common Options in the Import from PI Server Wizard
Import Raw Data from a PI Server
Import Plot Data from a PI Server
Import Interpolated Data from a PI Server
The Update Script
The Change Attributes Script
