JMP preferences enable you to specify general and specific settings and save the settings.
To change preferences
1. Select File > Preferences (Windows) or JMP > Preferences (macOS). The window in Figure 15.1 appears. The previous preferences page that you selected appears.
2. Click a category and make selections. Click Apply to see the results, and then click OK.
Notes:
• When you upgrade a subscription product, changes to preferences are maintained. In other JMP versions, you must customize the preferences after each upgrade.
• Your JMP preferences are remembered if you switch the JMP display language.
To search preferences
2. In the Filter box at the top, enter your text.
3. (Optional) To filter preferences by the version of JMP they were added in, click Version and choose minimum and maximum versions.
4. At left, click a category to see its results.
Matches are highlighted in blue. If you filter by version, the version number appears in a circle.
A search term can show up in these places:
• the preference itself
• a tooltip for the preference
• a list of options for a preference
To reset preferences to the default settings
2. Click Reset All, and then click OK.
