Fitting Linear Models > Model Specification > Model Specification Templates
Publication date: 07/08/2024
To obtain specific types of models, enter the correct effects in the Construct Model Effects panel of the Fit Model launch window.
In this section, the model effects X and Z represent continuous columns and the model effects A, B, and C represent nominal or ordinal columns.
Basic steps for constructing model effects are available for the following models:
Simple Linear Regression
Polynomial in X to Degree k
Polynomial in X and Z to Degree k
Multiple Linear Regression
One-Way Analysis of Variance
Two-Way Analysis of Variance
Two-Way Analysis of Variance with Interaction
Three-Way Full Factorial
Analysis of Covariance, Equal Slopes
Analysis of Covariance, Unequal Slopes
Two-Factor Nested Random Effects Model
Three-Factor Fully Nested Random Effects Model
Simple Split Plot or Repeated Measures Model
Two-Factor Response Surface Model
Knotted Spline Effect
Effects to be entered: X
1. In the Select Columns list, select X.
2. Click Add.
Note: For an example of a simple linear regression model, see Example of Simple Linear Regression.
Effects to be entered: X, X*X,..., Xk
1. Type k into the text box for Degree.
2. In the Select Columns list, select X.
3. Select Macros > Polynomial to Degree.
Note: For an example of a polynomial model in X to degree k, see Example of a Polynomial Effects Model.
Effects to be entered: X, X*X,..., Xk, Z, Z*Z,..., Zk
2. In the Select Columns list, select X and Z.
Effects to be entered: Selected columns
1. In the Select Columns list, select the continuous effects of interest.
2. Click Add.
Note: For an example of multiple linear regression with several predictors, see Example of a Regression Analysis Using Fit Model.
Effects to be entered: A
1. In the Select Columns list, select one nominal or ordinal effect, A.
2. Click Add.
Note: For an example, of one-way analysis of variance (ANOVA), see Example of One-Way Analysis of Variance.
Effects to be entered: A, B
1. In the Select Columns list, select two nominal or ordinal effects, A and B.
2. Click Add.
Note: For an example of a two-way analysis of variance model, see Example of Two-Way Analysis of Variance.
Effects to be entered: A, B, A*B
2. Select Macros > Full Factorial.
Or:
2. Click Add.
3. In the Select Columns list, select A and B again and click Cross.
Note: For an example of a two-way analysis of variance model with an interaction effect, see Example of Two-Way Analysis of Variance with an Interaction.
Effects to be entered: A, B, C, A*B, A*C, B*C, A*B*C
1. In the Select Columns list, select three nominal or ordinal effects, A, B, and C.
Note: For an example of a three-way full factorial model, see Example of a Three-Way Full Factorial Model.
Test for the effect of A with X as a covariate. Suppose that you have reason to believe that the effect of X on the response does not depend on the level of A.
Effects to be entered: A, X
1. In the Select Columns list, select one nominal or ordinal effect, A, and one continuous effect, X.
2. Click Add.
Note: For an example of analysis of covariance with equal slopes, see Example of Analysis of Covariance with Equal Slopes.
Test for the effect of A with X as a covariate. Suppose that you construct your model to allow the possibility that the effect of X on the response depends on the level of A.
Effects to be entered: A, X, A*X
Or:
2. Click Add.
3. In the Select Columns list, select A and X again and click Cross.
Note: For an example of analysis of covariance with unequal slopes, see Example of Analysis of Covariance with Unequal Slopes.
Consider a model with two factors, A and B, but where B is nested within A. Although there are situations where a nested effect is treated as a fixed effect, in most situations a nested effect is treated as a random effect. For this reason, in the model described below, the nested effect is entered as a random effect.
Effects to be entered: A, B[A]&Random
2. Click Add.
3. To nest B within A: In the Construct Model Effects list, select B. In the Select Columns list, select A. The two effects should be highlighted.
4. Click Nest.
5. With B[A] highlighted in the Construct Model Effects list, select Attributes > Random Effect.
Note: For an example of a two-factor nested random effects model, see Example of a Two-Factor Nested Random Effects Model.
Consider a model with three factors, A, B, and C, but where B is nested within A and C is nested within both A and B. Also consider B and C to be random effects.
Effects to be entered: A, B[A]&Random, C[A,B]&Random
2. Click Add.
4. Click Nest.
5. To nest C within A and B: In the Construct Model Effects list, select C. In the Select Columns list, select A and B. The three effects should be highlighted.
6. Click Nest.
7. With both B[A] and C[A,B] highlighted in the Construct Model Effects list, select Attributes > Random Effect.
Effects to be entered: A, B[A]&Random, C, C*A where A is the whole plot variable, B[A] is the whole plot ID, and C is the split plot, or repeated measures, variable.
2. Click Add.
4. Click Nest.
5. In the Construct Model Effects list, select B[A].
6. Select Attributes > Random Effect.
7. In the Select Columns list, select a third nominal or ordinal effect, C.
8. Click Add.
9. In the Construct Model Effects list, select C. In the Select Columns list, click A. Both effects should be highlighted.
10. Click Cross.
Note: For an example of a simple repeated measures model, see Example of a Simple Repeated Measures Model.
Effects to be entered: X&RS, Z&RS, X*X, X*Z, Z*Z
1. In the Select Columns list, select two continuous effects, X and Z.
2. Select Macros > Response Surface.
Effects to be entered: X&Knotted
1. In the Select Columns list, select a continuous effect, X.
2. Click Add.
3. Select X in the Construct Model Effects list.
4. Select Attributes > Knotted Spline Effect.
5. In the window that appears, select between the default number of equally spaced knots, specifying a different number of equally spaced knots, or specifying a set of custom knot points.
6. Click OK.
Note: For an example of a model with a knotted spline effect, see Example of Using a Knotted Spline Effect.
